Inertiaman
- Jan 27, 2024
Try attaching any standard non-ARC HDMI source to it (a DVD player, a streaming dongle, whatever) and you will come to a different conclusion. It cannot interoperate with any of those sources. Even audio only content from those sources (playing a CD in the DVD player) won't play though this port on the amp. Hence it is not an HDMI input.It's an hdmi input
The "return" portion of Audio Return Channel is a bit confusing. Especially in the case of components like the Wiim Amp which have only an ARC port, so there is nothing "returning" to the Amp. Only in the context of, say, an AVR with other standard HDMI ports does the "return" language make sense. Consider an Xbox, connected via HDMI to the AVR, then the AVR connected via ARC to the TV: in this case, the audio from the Xbox is sent with the video data through the AVR, to the TV, and then the audio data "returned" from the TV to the AVR.
Don't beat up the Wiim Amp for simply using the accepted (and I'd strongly bet legally required by HDMI licensing) term on their port labels. Any "blame" for the less-than-intuitive terminology can be directed to the HDMI consortium.
