Not worth upgrading to if the stock dac is good, i have never had problems with connetion and sound from bluetooth 5.0The main differences from the WiiM amp.
WiiM Ultra
Updated on 5/25/2024 Check out this fuller thread about our official announcement of the WiiM Ultra - https://forum.wiimhome.com/threads/meet-wiim-ultra-the-digital-hub-for-your-music.3487/ Updated on 4/19/2024 Hi Team, We're excited to give you a sneak peek at the WiiM Ultra, your future...forum.wiimhome.com
www.audiosciencereview.com
Is the 62 watt and 122 watt not enough ?
WiiM Amp Streaming Amplifier Review
This is a review and detailed measurements of the WiiM Amp streaming amplifier. It was sent to me by the company and costs US $299. I was pleasantly surprised by the good bit of weight this small box has. It will help it not slide with the weight of the speaker wires and such. Back panel shows...www.audiosciencereview.com
2x60 watt from a wiim amp is not enough if you have a big room (normal sensitive speakers) or low sensitive speakers
I would also be surprised if it would indeed go for only € 399, but to be fair, the only difference between the normal and the Pro that anyone could actually notice would be the improved wireless connectivity.The Non-Pro Amp is currently 369€ in Germany. Only 30€ more for the Pro would be kind of insane.
My guess is 439€ for the Amp Pro.
Someone said they asked at the show and were told that there will be an amp pro plus basically merging the amp pro with an ultra. No timescales, prices etc thoughI must say, as a owner of the amp, this product is a bit disappointing.
Though I expect the owners of the pro streamer felt the same about the pro plus?
I was really hoping, that if the product was a new amplifier, it would increase it's power output.
I also don't see why they didn't put the screen on the amp as well. Could that be saved for an amp ultra?
This amp feels like it doesn't really fit in their product line.
If they make an amp ultra, would that have a different DAC than the DAC ultra? Etc...
It's enough for my small secondary system in a 4x5,5m room.Is the 62 watt and 122 watt not enough ?
While that is great news, the naming just seems off to me.Someone said they asked at the show and were told that there will be an amp pro plus basically merging the amp pro with an ultra. No timescales, prices etc though
It might well be - that could just have been the name the attendee/representative gave. It’s probably far enough off that they can call it anything…While that is great news, the naming just seems off to me.
An amp with the ultra features should surely be named the amp ultra?
Yes, but it has PFFB which is suppose to help its performance. You can read about it on the ASR website were they measure audio products.Wait so the amp pro is the same 2x60w as the standard amp?
I own several pairs of full range speakers, so I tend to avoid subs, but thank you telling me about the PFFBYes, but it has PFFB which is suppose to help its performance. You can read about it on the ASR website were they measure audio products.
You can add a sub to the Wiim Amp Pro and relieve it of its low freq. duties which will also help the power output.
Just because the speakers are rated "fullrange" by some this is not necessarily a valid reason to avoid subs.I own several pairs of full range speakers, so I tend to avoid subs ...
Yea and you can dial the Sub in with most Wiim products.You really need to experience for yourself what good subs can do to lessen the burden on main speakers and amp to appreciate its advantage.
With all WiiM products featuring a sub out, I would say.Yea and you can dial the Sub in with most Wiim products.
I have no shortage of bass in my setups, indeed many people ask me where I've hidden the sub, so I will take the simplicity of a stereo setup and good stereo imaging over adding a third speaker somewhere.Just because the speakers are rated "fullrange" by some this is not necessarily a valid reason to avoid subs.
Good stereo imaging is not limited by adding a sub or two in any way. And adding subs is absolutely not about compensating for a a shortage of bass.I have no shortage of bass in my setups, indeed many people ask me where I've hidden the sub, so I will take the simplicity of a stereo setup and good stereo imaging over adding a third speaker somewhere.
