WiiM Ultra Firmware v5.2.704152 - Jan 10, 2025
5.2.704152 (In Progress)
Release date:
1 / 10 / 2025
What's New:
  1. Smart Preset: Create scenes for your favorite setups, including Input, Output, Playback, Volume, EQ, and Shuffle. Activate your scene with a single tap (requires app version 3.1.0). Learn more
  2. Simultaneous USB and Sub Output: Enjoy simultaneous USB and subwoofer output for an enhanced audio experience.
  3. Low-Delay Multi-Room Audio: Stream multi-room audio with low latency and perfect audio/video sync (requires app version 3.1.0). Learn more
  4. Remote Volume Step Customization: Adjust the volume step for each press of the remote’s volume buttons (requires app version 3.1.0).
  5. Replay Gain Enhancements: Replay Gain now supported for USB, NAS, Samba, and local libraries (requires app version 3.1.0).
  6. Remote Troubleshooting Improvements: Remote exception status is now provided to the app to assist with troubleshooting (requires app version 3.1.0).
  7. Screen Enhancements: Added a reboot option on the screen.
  8. Bluetooth & Network Pairing: In Setup mode, hold the play/pause button for 3 seconds to cancel pairing and network setup
Bug Fixes:
  1. Playback Enhancements: Fixed playback status after seeking, resolved artwork issues via Google Cast, and added sample rate/bit depth display on Alexa.
  2. USB Indexing: Addressed issues with artist and metadata display for certain music files.
  3. General Fixes: Various performance improvements and bug fixes.
Is it possible to set phono to preset with different EQ, like preset 1 phono with EQ of rock and preset 2 phono with EQ of electonica.
Yes, different EQ can be set for each preset.
I would strongly urge you to get a used Umik1 (or borrow) and use it to perform the measurement, or even better, get one and download the ”housecurve” app, and measure there, then ”simultaniously” apply PEQ values in the Wiim app and watch your measurements improve.
Point being you can see the changes ”live” and correct for discrepancies, it saves time and is more accurate. (According to me)
Agreed. I have a UMik1 and REW ....and will do that next.....Roon and JRiver can take the REW convolution zip files directly but for Tidal, etc, I'd have to input the EQ manually.
I think we need to update the WiiM app, 3.0.9 doesn't seem to do it yet
AHH ok, my ultras firmware updates this morning but no app update as yet. So you think adding phono as a preset will be available after the update. I would like to set presents for phono with different EQs and hopefully be able to rename those preset by EQ name
How would I add phono as a preset
The team said.
"you can edit empty presets to create input presets or modify settings"
The team said.
Sounds exactly what I'm looking for
Just got the update, nice!
Now we just need a larger remote with more preset buttons or dedicated buttons for the various inputs. 😀
That topic might be worth a separate thread. :) If we continue to discuss everything related to the new features in one thread it's gonna get a little cramped.
For some reason I do not get simultanous sub out when using usb out, I tried power cycling the ultra.
I’m using a SMSL PO100 Pro, do we need to wait for an app update as well?
I occour some problems with saving the presets, especially the Volume setting won't be saved as desired... It seems like "Follow actual Volume" wont be stored on vtuner radio presets
They say app version 3.1 is required for smart presets.
I added Vtuner to presets to check. It seems to work fine on my Ultra.
Is the volume set to this same?
Last update for ultra broke the trigger out control when using USB. I have my ultra connected to my Emotiva XDA-2 DAC using USB. The Wiim trigger out is connected to the Emotiva trigger in. When I turn off my Wiim Ultra, the emotiva powers off, but wiim powers on again triggering the DAC back on.
That also happens when Wiim tries to stand by automatically. They are in an infinite loop of standing by and turning on again.
Update: it looks like when my DAC turns off, Wiim is detecting that as a turn on signal through the USB, turning itself back on and turning the DAC back on through the trigger out.
If I turn the DAC off manually first, and then Wiim goes to the stand by process and the problem doesn't occur.
Same issue with a Topping D70 Pro Sabre via USB also using the trigger. It was working fine before the firmware update.
