Release date:
2 / 22 / 2025
What's New:
Bug Fixes:
5.2.708441 (In Progress)
Release date:
2 / 22 / 2025
What's New:
- Per-Source Group Audio Delay: Adjust group delay independently for each input source in multiroom audio.
- Preset Enhancements:
- Move presets (requires app v3.1.4).
- Presets now work in slave mode.
- USB Output Improvements: Reduced playback stuttering and improved subwoofer sound quality.
- Playback Enhancements:
- Smoother HDMI ARC playback.
- Fixed incorrect playback status and Pre-Gain issues after seeking.
- Resolved Audible playback issue via Alexa.
- Display & UI Updates:
- New VU Meter designs (requires app v3.1.4).
- Added remote pairing and Wi-Fi disconnect indicator.
- My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4).
- Prompt Sound Option: Ability to disable system sounds (requires app v3.1.4).
- Wi-Fi Stability: Improved connection reliability, especially for mesh networks.
- USB Output Enhancements: Reduced playback stuttering, improved subwoofer sound quality, and added the ability to select either maximum or fixed resolution (requires app version 3.1.4 or later).
Bug Fixes:
- LMS Fix: Fixed LMS reconnection issue.
- USB Indexing: Resolved USB scanning interruptions for M4A files.
- Pop Noise Reduction: Reduced pop noises when switching inputs or adjusting subwoofer settings.
- Radio Paradise Fix: Corrected a playback failure issue.
- General Fixes: General performance and stability improvements.
