Release date:
3 / 22 / 2025
What's New:
- HDMI ARC & Optical In Improvements: Now correctly displays bit-depth information for HDMI ARC and Optical In sources.
- TIDAL Queue Enhancements: Improved shuffle functionality with track order retention and faster queue performance.
- TIDAL Auto Play: Now supports auto-play; enable it in the WiiM Home App.
- Spotify Loudness Normalization: Added support for Spotify’s Loudness Normalization (requires WiiM Home App v3.1.5 for iOS, v3.1.6 for Android).
- Enhanced Radio Paradise: Added Serenity, Radio 2025, and My Favorites Mix stations with track-skipping support.
- Optimized CPU Performance: Reduced CPU usage for EQ processing and USB output, improving efficiency.
- Improved Presets in Group Playback: Presets now function correctly when the device is in slave mode.
- Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify, and TIDAL apps.
- Soundtrack SDK Upgrade: Enhanced performance for a smoother listening experience.
- Playback Fixes: Resolved multi-room audio crashes and fixed a skipping issue at the end of some MP3 files.
- Screen Enhancements:
- Improved VU Meter: Smoother and more accurate visual response.
- Smarter Display Behavior: Screen stays off when turned off, unless tapped.
- Extended Auto-Switch Time: Playback screen now appears after 15 seconds of inactivity.
Bug Fixes:
- KKBox Playback Fix: Resolved the playback skipping issue.
- General Fixes: Made several performance improvements and fixed miscellaneous bugs.
