WiiM Ultra Firmware v5.2.714249 - Apr 18, 2025
Anyone else having massive lip sync issues when watching TV (using hdmi arc) after this latest firmware? Ticket raised because I can't watch TV like this, it's horrible!
I noticed lip sync issues with TV sound via optical input, so perhaps it is related.
I had it until I performed a new "Synch Audio".
Afaik sync audio is for syncing when using different speakers (in different room setups), not for TV? Because no matter how I change the manual sync, it doesn't change anything for the lip sync problem.
Ok. It did for me. Changed the timing with about +25ms. The sync via HDMI is fine now. Was really bad before.
The sync measures how long time the processing of the signal is before coming out of the speakers.
Maybe you can control the picture delay on the TV to match this?
Or if TV out is not set to PCM, try that.
Tv is always set to PCM here. I'll see if I can change anything on the TV...
After the v5.2.711448 - Mar 22, 2025 update I was having issues with the TV/HDMI mode. When I would change the audio input mode to ethernet or other source and then back to TV the audio would not work on the TV/HDMI input. After this update, v5.2.714249 - Apr 18, 2025, this is no longer an issue.
I can well do without "smarter HDMI ARC" if it results in lip sync issues, 75% of what I use my Ultra for is watching TV either streaming from Prime, Netflix, Disney + and Plex. For that it's the best thing I've purchased, I'll keep reading this post till Wiim have cleared up all the problems that preople seem to be getting then I will think about upgrading the firmware. Thanks to all you folks who are posting your concerns on this forum, much appreciated.
Recently updated to 5.2.714249 with build date 20250418. After playing music without issue from early am today, mid morning suddenly no sound output over coax to my DAC. Checked everything and the WiiM is ‘playing music’ but no sound from my speakers. Was short of time so tried reboot, remove power then wait and power back on. Again, looks lie music playing but no sound either streaming or via my has attached to usb. I’m guessing a factory reset?
I just had a similar issue. After switching the output from DLNA back to line out, no sound from my speakers. Fortunately, a reboot fixed my issue.
If TV out is set to PCM, I see LPCM on the Ultra. many issues lately, sometimes lipsync, but mainly audio dropouts. Wiim support said it was better to use AC3, and used TV DD out for a long time without issue. might be the google streamer since I just heard an audio dropout streaming Netflix with TV set to PCM.
using PCM or DD output on your TV? Internal TV apps or streamer? Is the dialog fine? do you feel the need to adjust volume to hear dialog between loud passages?
