hgo58
Ok. Same way I used it when you asked.By HDMI mode, I’m referring to when the WiiM Ultra is set to the HDMI ARC input mode.
No, no, no. Please read carefully what I wrote!From what you’re describing, it sounds like you're requesting that the WiiM Ultra should not wake up from standby when the TV is turned on. However, we may not fully agree with this approach.
Yes. That's how it shall work. Not related to the issue at all.When you set your TV’s audio output to the WiiM, we want the WiiM Ultra to automatically wake up when you power on your TV—even if the Ultra is in standby. This ensures a seamless experience without requiring users to manually power on the device
Yes. Not related to the issue at all.This is precisely why many users appreciate HDMI CEC—it allows them to use a single remote to control both the TV and the WiiM Ultra, making everything easier and more intuitive.
That is exactly what I have done, as already described.For your situation, I recommend turning off the "Automatically output to WiiM when TV is on" option and switching the WiiM Ultra’s input to a non-HDMI mode
This is not the issue. IT IS NOT HOW THE WIIM IS BEHAVING. It is how the TV sees the WiiM Ultra. Please read my description carefully.With this setup, when you turn on your TV, the WiiM Ultra should not respond to CEC commands—assuming your TV correctly implements the CEC protocol.
It does respond to CEC. I have also described that. It also respond to the CEC protocol telling the TV that it shall change to ARC output send by the WiiM, even though the WiiM Ultra is in standby!However, if your TV does not fully implement CEC commands (such as properly responding to the 'audio output switch' command by WiiM Ultra), you may need to manually change the audio output setting on your TV.
Sorry, I simply don't know how to explain it to you. Please read carefully all the old posts. You are completely misunderstanding the issue.
ONE MORE TIME
With the WiiM Ultra in standby and the HDMI mode is OFF. When turning on the TV, the TV sees the WiiM as active and with input selection set to TV. This shall only be the case when HDMI mode is ON.
