WiiM Ultra Firmware v5.2.714249 - Apr 18, 2025
"Enhanced VU Meter: Smoother, more responsive visual performance."
The VU meters are still showing wrong scale and still max out with 100% volume (going all to the right and out of the screen).
Ha! Just got an ADept yesterday. Set up to 24/96 it showed 16/48 on the Ultra and WHA. Will check again. New firmware just installed.
It turns out this is sort of a combined issue. The Adept (and PocketADC) do not provide any bit depth metadata, which the Ultra uses to indicate the bit depth, so the Ultra defaults to showing “16 bit” no matter what. That also means I was mistaken that it ever said 24 bit. I just wasn’t attentive, I guess.
Luckily, WiiM says they will look into changing how the Ultra determines bit depth for the display (which would help for devices beyond just the two miniDSP devices in question), and miniDSP say they will look into updating the Adept firmware to include this metadata and have it adjust depending on the user setting (e.g. 16, 24, or 32). Sadly, the PocketADC has no solution since it’s running in “hardware mode” which prevents miniDSP from changing the lack of metadata.
6. Group Volume via TV Remote: Control group volume directly using your TV remote.
I hope this is also fixed for playing to persistent group from Spotify app via Connect.
After getting this update I can no longer see my president group for playback from the Spotify app.
Or if I have multiple groups I can see one of them but then my standalone Ultra is not showing.
It's off. If it was on the WiiM Ultra would turn on from standby and select TV input.
That part work ok.
The issue is when it is off. The WiiM Ultra is then still showing as online on the CEC. It should NOT show available, same way as it do when you deselect TV input.
This is a old bug that was actually fixed in a beta version (5.2.706937) 4 months ago but never made it to the main release.
Same for me, with my LG C2.
When the switch is off, the Ultra is still turned on when TV is turned on. As a bonus, the Ultra does not turn off when the TV is turned off, but maybe this is expected in this case.
Not exactly the same issue I described.
For me the TV "see" the Ultra as if is online and with input to TV, while it's actually still in standby mode.
Maybe your issue is related to the HDMI auto sensing?
Hm.
For me, when the "Automatically output audio to WiiM when TV is on" is switched off, the Wiim still turns on from standby and starts to play TV audio when TV is switched on. I think this should not be the case. On the other hand, the TV is still configured to HDMI ARC (instead of speaker). However I would expect this switch to cause no automatic HDMI audio.
Regarding the HDMI auto sensing, I seem to remember there was this switch previously in the Android app, but now I don't see it there - only "Auto-sensing of Optical In". And I have all the toggles in "Audio Input" switched off.
Thanks @tabata. I just attached my trusty old Squeezebox Touch with the Enhanced Digital Output feature installed to the Ultra optical input and put on some 24/192 Bruckner which plays at 24/192 with the Ultra Squeezelite. Ultra says 16/96 for the same file on optical input.
Hm.
Yes. It may look like HDMI auto sensing is always on now. That is too bad.
People have been asking for it to be separated from the optical input but not to be removed.
I will never have my TV to play on the Ultra unless I select the TV input option!
In that case it is nice that the TV changes to external speakers, as it does now.
T
5.2.714249​
Release date:
4 / 18 / 2025
What's New:
  1. Smarter HDMI ARC: Your WiiM Ultra will no longer act as a TV speaker when not in HDMI mode—giving you more control. Learn More
  2. DLNA Casting: Stream audio to any DLNA-enabled speaker for flexible whole-home listening. (Let us know if you run into compatibility issues!) Learn More
  3. Track-End Sleep Timer: New option to pause playback at the end of a track—perfect for winding down. (Requires app update: iOS 3.1.9 / Android 3.1.8)
  4. Auto-Resume Playback for Soundtrack: Playback resumes automatically after OTA updates, reboots, or network reconnections.
  5. Enhanced VU Meter: Smoother, more responsive visual performance.
  7. Screen Display Improvements: Input alias names now display correctly on the device screen.
  8. Wi-Fi Boost: Faster network scanning and connection times.
  9. Roon Sync: Improved multi-room sync for Roon users.
Bug Fixes:
  1. Amazon Music: Fixed playback issues for Prime users.
  2. Spotify Presets: Resolved unexpected ungrouping during group playback.
  3. TIDAL: Fixed skipping, playback errors, and incorrect quality cap on 24-bit/96kHz optical/coax outputs.
  4. Qobuz: Fixed track-start issues after skipping and unexpected playback jumps.
  5. Radio Paradise Enhancements: Resolved issues with track repetition during playback and fixed login failures caused by special characters.
  6. Alarm Fix: Resolved issues affecting alarms in Daylight Saving Time zones.
  7. General Performance: Stability improvements and behind-the-scenes optimizations.
Thanks for this upgrade - now one can control the volume for all 4 channels at the same time using dolby digital 4.0 with the apple tv remote !
