Steve Woodhouse
- Aug 11, 2023
Same answer as your duplicate commentWhy does the beta not have the new subwoofer latency feature but the new public app does ?
Did your firmware version number say beta and did the pop up menu to revert to non beta come up? Is it after that the check for update fails?Hi, it's like the beta is getting behind the main branch, so I’ve opened a ticket for getting back to the non-beta branch. They replied by saying that I would just need to go into device info and switching by clicking on firmware version. I’ve tried, and when it tries to check for an update, it doesn’t find anything (and we know that there are some newer versions of the 5252 beta). I’ve also tried to wait a few days, but nothing happened. Has anyone successfully updated to a newer version from the old beta?
I’ve clicked on the firmware version, then a pop-up comes up saying whether I wanted to stay on the beta or switch. I’ve clicked on switch and it’s started checking for an update. After a few seconds, it came up saying that I’m already on the latest version availableDid your firmware version number say beta and did the pop up menu to revert to non beta come up? Is it after that the check for update fails?
Maybe you need to raise another ticket to explain that. New firmware versions can take a while to rollout to the entire estate but it sounds as if you’ve already waited a few days.I’ve clicked on the firmware version, then a pop-up comes up saying whether I wanted to stay on the beta or switch. I’ve clicked on switch and it’s started checking for an update. After a few seconds, it came up saying that I’m already on the latest version available
Yeah, the ticket was from Thursday, so I’m gonna raise another ticket, thanksMaybe you need to raise another ticket to explain that. New firmware versions can take a while to rollout to the entire estate but it sounds as if you’ve already waited a few days.
Does the firmware version still show as "(beta)" like in your second screenshot? If so, the switch didn't work and the popup should show again, when tapping the version number.Yeah, the ticket was from Thursday, so I’m gonna raise another ticket, thanks
Yeah, it’s still showing beta, seems like something in the popup is broken and it doesn’t change where it checks for updates (I’ve tried to press it several time). Btw I’ve raised another ticket, let’s seeDoes the firmware version still show as "(beta)" like in your second screenshot? If so, the switch didn't work and the popup should show again, when tapping the version number.
If not: New ticket.![]()
Talking of which, still no 'ews from @WiiM Team as to wether we should stay on the beta stream and expect a new firmware at some point in the future or just jump off. Nothing has moved for a couple of weeks at least now while the non-beta has got a number of bug fixes. I suppose the bulk of the team is busy getting the Ultra readyYeah, it’s still showing beta, seems like something in the popup is broken and it doesn’t change where it checks for updates (I’ve tried to press it several time). Btw I’ve raised another ticket, let’s see
Update: they replied saying they removed my device from the beta, I’ve checked the app and it was automatically updated to the latest public fw, nice![]()
No, still in betaHi there,
Sorry to bother you with this again, but has Wiim launched its room correction tool? Is it official?
Thanks a lot for the quick answerNo, still in beta
No, it’s one decimal place, same as current PEQto make fine adjustment, hope wiim allows two decimal places for gain...
