Neither did I…Yes firmware update is required. None of the users here said that they received it.
Once you get the new firmware as mentioned in the release notes, you’ll find it under your device settings. It’ll step you thru the processI just installed the new Version 2.10 from the App Store.
Now, I did not find anything like room correction, nor would I know, where to look for it…
I have the WiiM Pro+ and there Version 4.86…
@WiiM Support do you have a rough estimation of when to expect Plex functionality?As someone who’s awaiting Plex support very impatiently I‘m not thrilled if streaming services I didn’t even know of are handled with higher priority…
Hi Team,@WiiM Support do you have a rough estimation of when to expect Plex functionality?
Last I heard it was changed to 6/22 but also still waiting for firmware for Room Correction on the Amp.Separate left and right peq that was slated on 6/15, anyone got this?
Will it include the Plex Radio features similar to Plex Amp? This feature would be tremendous.Hi Team,
We hope to release the first version of the native Plex client in August 2024. Please stay tuned!
10 band PEQ now on Mini with release of v2.6.620641
Steve most important feature set.Can’t wait to get home and try it.
Or do the RC on a WiiM that does support it and copy its results acrossIt should be noted too that, as the Mini doesn’t have RC, you can always get the HouseCurve app, which I think is <£10 for the full fat version, then input the results manually into the Mini’s PEQ.
I suppose it should just work. I'm not entirely sure how the extra functionality of Plexamp works technically, but I'm pretty sure the different automatic playlists, radio's etc are generated server-side, where all the indexing happens.Will it include the Plex Radio features similar to Plex Amp? This feature would be tremendous.
That's amazing!! Will there be a beta version?Hi Team,
I think we're on the same page. WiiM says that they are building a native client, so hopefully it will take advantage of the server-side generated automatic playlists.I suppose it should just work. I'm not entirely sure how the extra functionality of Plexamp works technically, but I'm pretty sure the different automatic playlists, radio's etc are generated server-side, where all the indexing happens.
Will separate left and right peq work on rc?Hi Team,
We'd like to provide some updates on our upcoming releases:
Thank you for your patience and support as we roll out these exciting new features!
- Room Correction: This feature will be available starting June 15.
- Separate 10-Band PEQ for Left and Right Channels: Scheduled for release on June 22.
- DLNA Cast: This will enter Beta testing on June 22.
- ASRC Fix: Scheduled for release on June 22.
- USB Out: This will enter Beta testing on June 22.
For the upcoming WiiM Amp update, what would "USB Audio Output" be used for?
