WiiM Ultra Firmware v5.2.704665 - Jan 15, 2025
WiiM Team
WiiM Admin
Staff member
Moderator
5.2.704665 (In Progress)
Release date:
1 / 15 / 2025
Bug Fixes:
  1. Screen Display Enhancements: Improved the reliability of album cover display.
  2. USB Out Fix: Fixed an issue preventing standby mode and resolved a no-sound issue with certain DACs when using USB Out.
  3. Google Cast Enhancements: Fixed an occasional issue that prevented bit-perfect playback on Google Cast Audio when using USB out.
I'm glad to see updates addressing USB out issues and Google Cast. Has anyone tested the album cover display reliability after the update? Curious if it resolves the inconsistent display I noticed earlier.
Release date:
1 / 15 / 2025
Bug Fixes:
This new update nuked my entire setup. All presets gone. Subscriptions gone. Won't save new setup. Is there a roll back ?
Have you tried rebooting the device? I have not had that problem with mine. There may have been some error during the update.
Mine seems ok so far but what concerns me is that this updated automatically
Can we have a toggle switch for automatic or manual updates
Nervous as I am an ex Sonos user
There isn’t a manual rollback, you’d need to contact WiiM via the more/feedback section in the app so they can inspect your logs. Sounds like it’s done a factory reset which is pretty unusual - my devices (all different) have never done anything of that nature in the few years I’ve had them. I know that’s no consolation for you at this moment in time, but it is very rare.
I’d submit a ticket then do a power off, wait half a minute and turn it back on and see if it behaves itself again.
Anyone else lose the ability to adjust volume from their iphones after this update? My volume control is locked, WiiM app, Spotify app, Pandora app... totally unable to control the volume from my phone. I have to physically go to the receiver and turn the knob.
The USB fix did not work. My Ultra is either still sending power or some sort of audio signal. Whatever it is, my DAC never shuts off.
When I power my Ultra off, the DAC continues to say it's receiving a signal at whatever sample rate it was last playing. However, as soon as I unplug the Ultra's USB cable, the DAC stops showing a sample rate and after a minute or two it shuts off automatically.
