An Inside Look at the WiiM Sound
We're excited to give you this closer look at what makes the WiiM Sound tick. This exploded view shows all the components that come together to create our first smart speaker and we think you're going to love what's inside.
What You're Looking At​
After years of building award-winning streamers and amplifiers, we listened to our community asking for an easy edition to their WiiM home setups to bring high-resolution, multi-room smart audio in a convenient package. So we built WiiM Sound.
This was designed specifically with flexibility in mind. You can use it to expand WiiM home setups to rooms without speaker setups existing already, to bring audio easily to any space, to expand a WiiM home theater setup to be 5.1 with wireless surrounds or center, and to make whole home setups, even in rooms not traditionally used as dedicated listening room.
At the core, you've got a 4" paper-cone woofer paired with dual 1" silk-dome tweeters to delivers tight, natural mid-bass, with smooth, extended highs and wide dispersion. The result? A coherent soundstage that's clear, refined, and never harsh. Further customizable with our RoomFit software and EQ or PEQ.
This breakdown shows how we've packed all that performance into a compact form factor that fits anywhere in your home—on a shelf, table, counter, stand, or even wall-mounted.
The WiiM Sound delivers 100W total output and covers a frequency range from 35 Hz all the way up to 20 kHz. That means you're getting real bass extension and crystal-clear highs, all from a speaker that measures just 5.7" x 5.7" x 7.5" and weighs 5.5 lbs. And if you're looking enforce the low end, you can pair the WiiM Sound with the WiiM Sub Pro wirelessly.
The internal design ensures you get room-filling audio no matter where you place it, and our RoomFit technology (previously called Room Correction) actively takes precise acoustic measurements of your space, crafting customized corrections specifically for your room.
Coming Soon​
WiiM Sound will be available soon on Amazon and select retailers. It will be priced at $299 US, £299.00 UK, and €349.00 EU when it becomes available.
Want all the details? Check out the full specs and info on our website.
We can't wait for you to hear it!
Don’t think WiiM have done that with any of their previous devices, and I wouldn’t see the WiiM Sound being any different. Hopefully you’ll start seeing some more reviews rather than the rather weak Vine reviews
I have seen the WiiM Ultra advertised (Google search) from what I paid to 110€ plus. So I think that the higher price is from when it first came out. I have even seen some shops selling the silver model 40€ higher than the grey one. The company I used in Czechia charged the same for both versions and I picked the silver. Although I bought online they do have a brick and mortar store.
Coming from an old Sonos system, I exited due to the app debacle. Used to have a Sonos port for my main sound system, a Sonos 3 in my office, Sonos 1 in every other room and a Sonos move for the garden and kitchen plus a roam for travel
Now have a WiiM ultra for main sound system, a WiiM amp ultra for office and a WiiM sound for kitchen. Pretty happy with the change - works so much better than Sonos especially having persistent groups for Spotify connect rather than having to group manually - love that.
I long for a water resistant / battery power version similar to the Sonos move and I am set, wired until then and we'll keep Sonos roam to use in the garden
