Brantome
- Oct 20, 2022
True. And as soon as that’s there, people will be clamouring for that to be in room correction too…Still waiting for the per channel PEQ beta![]()
I think with so many features being developed and in beta they may have been outnumbered.True. And as soon as that’s there, people will be clamouring for that to be in room correction too…
And do not forget the possibility to give in the figures for humidity and room temperatureTrue. And as soon as that’s there, people will be clamouring for that to be in room correction too…
I figure it needs to come together, how can PEQ be split into 2 channels if there is no per channel correction in the RC?True. And as soon as that’s there, people will be clamouring for that to be in room correction too…
Guess in the first instance RC would just duplicate the values in each channel.I figure it needs to come together, how can PEQ be split into 2 channels if there is no per channel correction in the RC?
Well, as usual, I may be talking out of my ass.
And re your second comment, never![]()
Yeah, they could have a L/R/Combined switch rather than just L/R to allow you max freedom in editing the values.Let me know if you are not already exhausted.
"duplicate the values in each channel"
I could not figure out how this actually works.
For example, my Yamaha AVR reflects the measurements for each channel in the PEQ for each channel.
But if the WiiM RC can't do per-channel measurements, how does it reflect them in the per-channel PEQ?
When you say "duplicate", do you mean reflect the same value on the left and right channels? But in that case, it seems to me that it would be quite difficult to adjust manually.
Thank you.
Edit:
Please forget it.
Perhaps manual adjustment is not a problem if the left and right PEQs are adjusted to the same value.
Are you planning to connect the Ultra to speakers at all?Hi everyone, I am trying to understand how this works in order to decide whether to buy the new WiiM Ultra (with its USB input) and effectively use it as a DLNA server instead of a NAS. So will this work to transmit bit perfect audio or no:
If all you're after is a DLNA server there are much cheaper and better alternatives.
If you're using a third party control point then you don't need DLNA Cast, just use the Ultra as the source (media server). Have you used DLNA before?Yeah, but not with the WiiM app. Not sure about cheaper though, a relatively good NAS costs just the same.
Not sure I follow you there… Yes, I have used DLNA beforeIf you're using a third party control point then you don't need DLNA Cast, just use the Ultra as the source (media server). Have you used DLNA before?
I wasn't thinking of a NAS, something like a Raspberry Pi.
The Ultra will appear in your DLNA control point just like any other DLNA server e.g. MinimServer, Plex etcNot sure I follow you there… Yes, I have used DLNA before
And do not forget the possibility to give in the figures for humidity and room temperature![]()
Hi, I raised a ticket asking if the original DLNA Cast beta firmware was to be updated since its initial release almost a month ago and got this ambiguous reply “There is currently no DLNA Cast firmware update. Please be patient, as there will be a version of the WiiM app updated next week to support this feature.”Moderators?, WiiM?
I signed up for the Beta but got no response. Is this still open?
Thanks for the update. Excellent!Hi, I raised a ticket asking if the original DLNA Cast beta firmware was to be updated since its initial release almost a month ago and got this ambiguous reply “There is currently no DLNA Cast firmware update. Please be patient, as there will be a version of the WiiM app updated next week to support this feature.”
I’d hold off till next week and see what transpires.
You need to sign up for the DLNA cast firmware via the form in the first post of this thread.Hi, I only just found out that I can no longer send my home HI-Fi to my Sonos speakers and that WiiM has stopped supporting Airplay 2 which used to do this. I emailed them and they told me to try DLNA but with no instruction or help and noting in the manual that I can see. Googling I have found that if I go to Browse/Home Music Share I can see my 3 Sonos speakers but I cannot seem to do anything with them. Is anyone able to point me in the right direction? Thanks. I might ask Amazon for a refund if I cannot get it to work. Appreciate your help. I only bought the WiiM to send my home stereo to my Sons speakers and without this it might as well be a brick for me.
