azoriusmage
Senior Member
- Apr 23, 2024
Suspect the issues are more WiiM end than Qobuz as my Marantz amp is rock solid with the beta Qobuz app
I’m inclined to agree since it’s working fine between two non-WiiM devices on my network.Suspect the issues are more WiiM end than Qobuz as my Marantz amp is rock solid with the beta Qobuz app
What's the date of the firmware on your Pro?Hello. I have the Wiim Pro and a Samsung A8 tablet with Android. I am a beta tester of Qobuz connect, and I have everything installed with the latest versions, both in Wiim Home and in Qobuz Beta, but from this last app I can't see my Wiim Pro.What's wrong?Regards.
Some things to try:Hi.
20241223
firmware 4.8.639532
I use Tidal Connect as well, and of course while not always flawless, it's a more mature product, having been GA longer. But on the same tracks, I hear a layer of processing with Tidal that I don't hear with Qobuz, so I fervently hope the latter -- and its CE partners -- can debug any issues found in this phase of the development and release cycle.Thank you for your reply and operations to perform but I have Tidal and I use the Tidal Connect feature and it has always worked fine from the beginning, I know that Qobuz is a beta feature but my Wiim Pro was updated to the latest version that allows its use as Tidal connect and my tablet was also updated to its android version. I don't know how to use Qobuz connect if I can't see my Wiim Pro device from my tablet.
The process for installing the iOS beta app is documented on the Qobuz Connect Welcome page. Did that not work for you?I have an iphone but I don´t access to the beta app
Hi.The process for installing the iOS beta app is documented on the Qobuz Connect Welcome page. Did that not work for you?
Is there a beta app version for Android that you perhaps haven’t installed?Hi.
Yes, on my iPhone the Qobuz Beta works perfectly and I can choose the Wiim Pro device, but on my Android tablet it remains invisible.
Hello. If you read a little further up you will see that I have the Android version of Qobuz beta installed and that the Wiimhome app is updated to support this version of Qobuz.Is there a beta app version for Android that you perhaps haven’t installed?
I held my tongue that it could be a Samsung issue, but maybe it is (Samsung does some, um...interesting things with their Android implementations). Please go to the Qobuz Qconnect feedback site and give them the details. It may be something they can work around...as so many other software developers have had to. Make sure you give them the Androiid version/build your tablet's on.Hi.
When you have the Qobuz Qconnect beta app running on your iPhone, does it show up as a Connect endpoint on your tablet (it may be identified as a Network device), or vice versa? Is the beta app version running on your tablet Qconnect-beta01 or Qconnect-beta02 (you can find this under Settings - Help/Contact).Hi.
Hi.When you have the Qobuz Qconnect beta app running on your iPhone, does it show up as a Connect endpoint on your tablet (it may be identified as a Network device), or vice versa? Is the beta app version running on your tablet Qconnect-beta01 or Qconnect-beta02 (you can find this under Settings - Help/Contact).
When you go to Settings-Help/Contact, what verbiage does the Version line display?Hi.
I think the beta version Is the beta 02 because is the second update. The version inside Qobuz beta es 8.4.0.1
The version inside Qobuz beta: settings/help/contact is Version 8.4.0.1When you go to Settings-Help/Contact, what verbiage does the Version line display?
