Ongoing Beta Beta Test: Simultaneous USB out and Sub out
Can you explain why it is not possible to make corrections on separate channels with a sub?
Are you taking L/R independent rc? From what I read here before it did not sound good. Only stereo rc is allowed.
Hi Flatron7,
I’ve just added your device to the beta list. Please check and let me know if everything is correct.
hi thanks. I received the update in the photo this morning. is it the right one?
I know
I know that currently L/R correction bypasses the Sub. That's why I'm asking if it's possible at all, or if there are some technical (or other) reasons that prevent it.
after testing no sounding good for me.. i see severe sub alignment issue and the wiim amp refuses to align
I'm trying the Beta usb out with sub out. I've had a problem when trying to automatically sync the sub to the front speakers. The sub signal doesn't start and the app says an error.
Send message to wiim via app. They will look at your log and assigned a fix.
As above, raise a ticket via the more/feedback section in the app
I can confirm. Speakers/Sub sync is broken when USB out is active (SPDIF works). I sent ticket in the app.
Same here seems beta is not upto the expectation
It was reported that auto timing not working correctly. Please send message to wiim via app so they can look at your log and fix the issue. We want this feature to be release on Jan 7 if all issue are reported sooner.
Is the "Speakers/Sub sync" issue mentioned above something that can be manually fixed by setting a "time delay" parameter to the subwoofer or main speakers? Or is it something more complex that cannot be fixed by manual parameterization?
Hi WiiM Community,
We are seeking beta testers for the simultaneous USB Out and Sub Out feature, available exclusively on WiiM Amp, WiiM Amp Pro, and WiiM Ultra.
How to join this Beta?
If you are interested in beta testing this new feature, please provide your Wiim Forum username and MAC address in the Beta Test link.
Thanks!
WiiM Team
I have sent MAC adress. When do i get the update?
