WiiM Ultra Firmware v5.2.703434 - Jan 3, 2025
5.2.703434 (In Progress)
Release date:
1 / 3 / 2025
What's New:
  1. Google Cast SDK Update: Enhanced playback support for multiple music streaming platforms, including Roon, Plex, SiriusXM and BubbleUPnP.
  2. Persistent Group Support: Enhanced quick selection and synchronization for multi-room audio across devices. Learn more.
  3. USB Indexing Enhancements: Added support for APE audio tracks, corrected artist name display, and resolved unexpected interruptions during USB scans.
  4. Playback Improvements: Enhanced metadata accuracy for local storage music and optimized memory usage for improved stability.
  5. Soundtrack SDK Enhancement: Upgraded for a better listening experience.
  6. TIDAL Connect SDK Update: Upgraded for improved playback stability and resolved crash issues.
  7. Enhanced DHCP Compatibility: Improved stability and reliability across various routers.
Bug Fixes:
  1. Alarm Fix: Easily stop the default alarm tone using remote buttons or the app's play/pause button.
  2. LMS Volume Control: Resolved an issue where Fixed Volume settings were lost for LMS Volume Control.
  3. General Fixes: Various performance improvements and bug fixes.
I find CC is super slow to start, especially on the SiriusXM app. It seems to hang, and if I change the channel and back again it kicks in. It really is temperamental
Does it work if you cast from other apps, such as BBC Sounds or Global Player? Isn’t bubbleupnp a special case?
Don't know if it's a special case, but I'm pretty sure others posted that they couldn't get 192 via bubble either.
I'll have to find something else that can CC at 192 to try!
I know I was asked to try Qobuz to see if I get 96khz, but that'd probably mean signing up again as I used to have it.
Sometimes Tidal shows me CC instead of / as well as connect, so I'll see if that happens too.
Hi
I just tried streaming from Qobuz with CC via Bubble of a 24/192 album. The 1st track starts immediately and Bubble returns 24/192, but I think Bubble is precisely a special case.
Even with the old CC, using it directly from Qobuz, I had 24/96 ( now CD quality ) and using it from Bubble I had 24/192
Hi
Are you sure bubble is using Chromecast and not DLNA ?
More than one wiim, or more than one ultra?
Ultra only atm??
True…
Edit: can’t recall from the beta if the option for groups only appeared when there was more than one grouping candidate whose firmware also supported persistent groups, and it’s a while since I only had one WiiM ;)
True…
I'm only going off what I think @Wiimer wrote recently, words to the same effect - need multiple devices all capable of being in a persistent group. And right now, that's just ultras.
I only have Android.😄
Ditto, but my android 3.0.9 app doesn't have this group option at the top of the devices screen either.
Maybe we need to do something somewhere else first, such as buy two ultras :ROFLMAO:
Is it possibly a hang over from you having the beta for these groups?
