WiiM Ultra Firmware v5.2.708441 - Feb 22, 2025
5.2.708441 (In Progress)
Release date:
2 / 22 / 2025
What's New:
  1. Per-Source Group Audio Delay: Adjust group delay independently for each input source in multiroom audio.
  2. Preset Enhancements:
    • Move presets (requires app v3.1.4).
    • Presets now work in slave mode.
  3. USB Output Improvements: Reduced playback stuttering and improved subwoofer sound quality.
  4. Playback Enhancements:
    • Smoother HDMI ARC playback.
    • Fixed incorrect playback status and Pre-Gain issues after seeking.
    • Resolved Audible playback issue via Alexa.
  5. Display & UI Updates:
    • New VU Meter designs (requires app v3.1.4).
    • Added remote pairing and Wi-Fi disconnect indicator.
  6. My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4).
  7. Prompt Sound Option: Ability to disable system sounds (requires app v3.1.4).
  8. Wi-Fi Stability: Improved connection reliability, especially for mesh networks.
  9. USB Output Enhancements: Reduced playback stuttering, improved subwoofer sound quality, and added the ability to select either maximum or fixed resolution (requires app version 3.1.4 or later).
Bug Fixes:
  1. LMS Fix: Fixed LMS reconnection issue.
  2. USB Indexing: Resolved USB scanning interruptions for M4A files.
  3. Pop Noise Reduction: Reduced pop noises when switching inputs or adjusting subwoofer settings.
  4. Radio Paradise Fix: Corrected a playback failure issue.
  5. General Fixes: General performance and stability improvements.
Just checked on my D30 Pro... it's the same. Just 32bit.
Thank you so much 😊.
I am a little relieved that you are the same as me.
I received the following reply from the support team.
"This issue occurs because the UAC you are connected to only supports 32-bit, which is why it cannot be selected."
This is a bit odd since the D30 Pro's USB is supposed to 16-32 bit, but this seems to be normal.
Btw when I connect the Bluetooth adapter to the Ultra's USB it shows this. There seems to be no problem here.
Same on iOS and Android for me - just shows 32 bit
This could be a problem if it’s just straight 32 bit. What if you’re playing 16/44? Will it play 32/44? Unlike with a choice of 16, 24 the dac can switch with either bit depth to make it bit perfect.
If you don’t select fixed resolution then it will be bit perfect
Like I said, I'm not sure 😂.
(My DAC does not display bit depth.)
For those having an issue with moving presets, try the following.
1. From the devices screen press the gear icon
2. Go to presets
3. Click on edit
4. Press and hold on the preset that you wish to move until it is highlighted and slide the selected bar to where you would like it moved to and release.
5. Hit done.
Hope this helps (and works) Ronnie
View attachment Screen_Recording_20250226_122024_WiiM Home~2.mp4
2. Go to presets
3. Click on edit
5. Hit done.
The same works from the "Favorites".
I've had the software update and the firmware update but don't see the new VU meters. Ive cleared the cache etc but still don't see them
That would I explain it as I'm using Android, thanks
That actually does explain it fully. :)
See here:
See here:
That note was updated at some point, as it did not originally include that iOS part.
-Ed
I checked on my DAC. Although the only option is 32 bit, the DAC plays at 16 or 24 bits consistent with the album🤗
