What speakers are you using?
I started this hifi lark in 1975. Originally had Wharfedale Lintons, which were replaced with KEF Q3's in 2000.
I was going to upgrade them, but the WiiM Pro and room correction has improved things so much I'm not so sure I need to now. :)
The room is the biggest part of any system, upgrade it and you may never need to upgrade anything else.
As it's expensive to upgrade a room, and will probably destroy it's aesthetic value, room correction is a good second option.
As of today I'm running 2 Wiim Amps. The 1st I bought on Black Friday for system 2 with the tv and use mid 80s Arcam Two Plus.
Ah! I recognise those systems. Those old Arcams of yours sound superb, though I haven't heard them with the WiiM amp. (y)
Back in December I got an Amp Pro for home music stereo listening. When the tiny Polk speakers (part of a previous 5.1 home theater setup) weren’t quite cutting it, I decided to plunge a little deeper and treat myself to a pair of Paradigm Monitor SE 6000F’s. I picked those because they showed up in a search for high-sensitivity speakers and were very reasonably priced compared to other options, though I probably could easily have gotten away with the 3000F’s. Too late, and they’re too damn big and heavy and I’m too old to mess with repacking and returning. And anyway, they sound fantastic. They’re combined with an older JBL PSW1000 powered sub, which is still doing its job quite nicely. It took me a few days of messing with balances and eq’s, but I think I finally have it right where I want it. Nice fat (but not muddy) bass, and crisp detail that clearly cuts through over it. My only music sound source is Bluetoothing Apple Music or Sirius XM from my iPhone, but I also have an optical line from my tv to supplement a Bose soundbar and sub when I feel like rattling the shingles with a loud movie. But it’s primarily just for music.
I’ve been spending many hours when I can going back through my library, most of which was imported CD’s from 70’s through 00’s, with a growing bit of newer stuff added from Apple Music. Everything sounds anywhere from great to incredible. I’m so impressed with this little amp. I’ve always managed to assemble passable setups with budget gear, but never really had anything that I was totally happy with. This is the most I’ve ever spent on a home stereo, and it was worth every penny, as it continues to blow me away every time I fire it up.
Wimp Amp Pro with Fyne F500's. Only acquired a couple of weeks ago. So far so very good. The speakers are on Mission Stancette stands bought cheaply on Ebay. They are currently £300 off at Richer sounds, originally £799 now £499,
  • Like
Reactions: N_K
Morning all!, my setup is , Wiim pro plus, into an Arcam A5 amp running a pair of Dali Oberon 5,s, decent enough,, for now,!!😁. 👍👍
  • Like
Reactions: N_K
I recommend anyone looking for good and affordable floorstanding speakers to try out the Dali Spektor 6. I treated myself to them as a “just for fun” second loudspeaker on the “B connection” of my Yamaha amplifier and am very impressed by what is possible at this comparatively low price.
The room is less of a problem with open baffles than with box speakers. The key is placing them away from walls.
My configuration is wiim ultra, temple audio bantam gold, eltax monitor 3. with rc I even deleted a sub elac, fantastic sound.
I started by connecting the Wiim Amp to the small Usher s-502 monitors. These are very good monitors, but for me they sounded too bright and shrill with the Wiim Amp. Then I connected the Wiim Amp to the Quad 12L speakers. These speakers add warmth and refinement to the Wiim AMP sound. The stage became wider and better arranged. I really like this combination and I think the Quad 12L speakers are very good match with the Wiim Amp.
Newb in here, but long time listener…
WiiM Amp Pro driving Elac 63’s! Sounds awesome!
Still working on the tv’s sound output quality…
EQ suggestions would be appreciated!
Hello, I have a couple of Canton Vento 896.2s in use. These are powered by a Denon 1700ne stereo amplifier. The concept is complemented by the Elac 2070. The room measures 6 x 5m. The distance to the stereo triangle is 5m. I generally listen to music without a sub. Only for films is this activated via a Denon AVC 4700. Sound is always very subjective. At small screenings with friends, people's mouths drop open. Common comments are: I've always wanted to hear music like that. I don't have to go to the cinema to watch films. Brutal sound power with great effects. Of course, a center and rear speaker are included in the delivery.
I wonder what could change if applying some EQ changes to the monitor speakers..
I changed from a wiim pro plus, going into an arcam a5, driving a pair of dali Oberon 5,s.. To a wiim amp pro running the dali Oberon 5,s, still deciding on what sounds better,,, 👍👍
Wiim Pro user but always interested in hearing about speakers used. Dali Menuet SE incredible clarity and the Wiim sounds fantastic-amazing value.
Wiim amp pro, running a pair of dali Oberon 5, s, sound good, still testing it out fully though,,
After a very long period of lying dormant, I have just connected my WiiM Amp to my Bi-Wired Tannoy 615 speakers.
These speakers have sat unused for well over 15 years, possibly even 20 years.
The Amp has no problem driving them, and as a result of this, I have set the Volume Limit to 75%, and that still allows me to have plenty of volume available for use.
I definitely don’t need a subwoofer with these speakers.
