WiiM Ultra Firmware v5.2.630635 Update - Sep 27, 2024
Hi Slartibartfast,
Two options are now available for the Subwoofer: 1. Subwoofer Bypass Mode 2. Main Speakers Output Bass. Please review the output frequency settings for both the Subwoofer and Main Speakers:
#1
Subwoofer Bypass Mode: On
Main Speakers Output Bass: Off
The subwoofer will output full-range frequency audio, while the main speakers will output audio frequencies above the crossover frequency.
#2
Main Speakers Output Bass: On
Both the subwoofer and main speakers will output full-range frequency audio.
#3
Subwoofer Bypass Mode: Off
The subwoofer will output only audio at the crossover frequency, while the main speakers will output full-range frequency audio.
#4
The subwoofer will output only audio at the crossover frequency, and the main speakers will output audio frequencies above the crossover frequency.
I think we've already figured that out, the question is why grey out the x over in option 1 and 2
Hi Slartibartfast,
#1
#2
#3
#4
I can't try any of this as I'm still on the beta firmware for L/R room correction..I have no idea why the beta firmwares don't get updated with new official features but that is how it is.
I known what your thinking having option won’t hurt if you don’t like it.
Bit it's a pointless and confusing option. It's poorly designed, that's my point. If I wanted multiple options I'd invest in a raspberry pi and do it myself!
When you enable sub bypass the crossover will greyed out. So if you want to change it, disable it and make a change then enable. Ask wiim, I don’t know why it greyed out when sub bypass is enabled. In theory it make no sense but in practice it will rewarded you how good a sound would be.
Haha, that’s why I don’t like to be beta tester because if new features comes out you will be left behind. Do you still want to be beta tester? If not, you can opt it out where the update location.
I’m using iPhone 16 pro max. I upgrade yearly even there’s just hair improvement.
We need a method to set the right value.
Method 1:
Calculate. 34 cm difference in distance equal 1 ms.
Method 2:
Listen. Louder is simply always better in this case.
Wiim already explain it. When toggle is enable is full range is that simple. You want double dose bass? Enable both toggle.
Please, spend some time reading instead writing at least from time to time. Different topic.
In my opinion, this is one of the best feature since rc. I’m sure you will disagree and respect you for that.
Method 1:
Method 2:
My sub is sitting next the right main speaker. I used REW and adjusted the delay until the response around the crossover was maximised and ended up with 6ms. I suppose you could play a tone at the crossover frequency and adjust the delay and listen for the loudest setting.
It's already there, just manual,.not automatic (which is difficult anyway).
That's what I was hoping for. It's really difficult to do it manually. Mind sounds great between 0ms and 30ms which isn't right. Ears are crap at so many things.
Yep. :)
If you cannot hear a difference, what improvement do you expect? ;). Acoustically measuring the distance to the (slow) subwoofer is not that easy at all. Just playing a tone right at the crossover frequency and dialing in the number for the loudest response can be done even without using REW.
RoomPerfect, the room correction system developed by Lyngdorf and one of the most advanced in existence, doesn't even attempt to determine the distances.tonthe speakers. Users have to enter them manually.
Yep. :)
Thank you. In which case I'll use what sounds OK given the range of effectivity. I rarely use my ears to calibrate anything because they're poor measurement instruments (ears generally not just mine).
As you said, the crossover is grayed out when "Subwoofer bypass mode (SBM)" is turned on.
This is probably because it is an exclusive process. Just as moving the volume slider unmutes the mute, moving the crossover slider when SBM is on will turn SBM off, causing black smoke to rise from the WiiM. To prevent this, it is grayed out and locked.
Yes, these are completely my imagination, so @WiiM Team please correct my mistakes. 😁
After a quick test of SBM, it seems to be working as described by @WiiM Support.
Cross 60Hz / SBM off
Cross 60Hz / SBM on
Cross 150Hz / SBM off
Cross 150Hz / SBM on
* The graph shows the curve for the main speaker. I have not tested the sub as it is not connected to my Ultra.
Cross 60Hz / SBM on
Excellent. Thanks for providing proof that it does actually work 👍. It still shouldn't be greyed out though 🤔
Cross 60Hz / SBM on
Thank you for doing this. My ears suggested this is how it worked but it's not intuitive in how it's setup. The second option now makes sense, you have a sub with full range and speakers full range, so you can either set a custom crossover point, or use the main speakers natural roll off and let your sub fill the gap, so essentially how you would set it up without dsp.
