EddNog
Senior Member
I’m not on beta firmware.Does it need a beta firmware? I got the app update it doesn’t do it.
-Ed
-E
I got the latest app but can’t get independent rc with sub to work.I’m not on beta firmware.
-Ed
It does need beta firmware and you need to fill a form in to get it like the old days. There is a new thread about it.I got the latest app but can’t get independent rc with sub to work.
Are you signing up? I know you like rc especially independent with sub.It does need beta firmware and you need to fill a form in to get it like the old days. There is a new thread about it.
Hi WiiM Community,
We are recruiting beta testers to experience our brand-new "Independent L/R Room Correction with Subwoofer" feature. This innovative tool allows for precise adjustments to each audio channel under a subwoofer output environment, enabling you to customize the sound according to your room’s unique characteristics. It’s especially ideal for optimizing performance in irregular layouts or obstructed channels.
To use this feature, you’ll need to download the upcoming app version 3.1.4, which will be officially released in a few days. Join us in testing this cutting-edge...
I’m not testing the L/R correction with sub since I use a separate device for room correction and bass management.I got the latest app but can’t get independent rc with sub to work.
I would if it was as simple as clicking a link in the app but I'm not doing it by filling in a form.Are you signing up? I know you like rc especially independent with sub.
Hi hgo58,It's now possible to move and rename Preset entries. Funny thing is that all my Presets were renamed automatically with a timestamp appended after the original name, after the update.
If you don't see the new VuMeters you haven't lost anything because, as I said, they are horrible, useless and unreadable.I updated the firmware, updated the app to 3.1.4, and cleared the app storage. I'm still not seeing the new VU meters. Am I missing something?
Yes it isCould be Android vs iOS ? Mime is the former
To summarize:
In my IPAD I can select the meters
In my Android tablet the option is not there
I'm not sure of the details, but my Amp pro sometimes produces noise when played back in bitstream. And I'm thinking this has something to do with the noise that happens with wireless Dolby.Smoother HDMI ARC playback is quoted as a feature in this update, what does that actually mean? I was unaware of any problems.
You can slide the 12 Presets around to the order you want. Just as you can with a playlist.What does ‘Move Presets’ mean?
Change the order, so (for example) you can create a new one and make it Preset 1?
Been 3 so farIt usually takes atlist 2 days after get posted here.
Be patient young padawan! I’m on same boat as you are wanted to get it on the fly.Been 3 so far
Strangely I got the 3.1.4 app before it was posted on here![]()
