WiiM Ultra Firmware v5.2.708441 - Feb 22, 2025
WiiM Team
WiiM Admin
Staff member
Moderator
5.2.708441 (In Progress)
Release date:
2 / 22 / 2025
What's New:
  1. Per-Source Group Audio Delay: Adjust group delay independently for each input source in multiroom audio.
  2. reset EnhancemPents:
    • Move presets (requires app v3.1.4).
    • Presets now work in slave mode.
  3. USB Output Improvements: Reduced playback stuttering and improved subwoofer sound quality.
  4. Playback Enhancements:
    • Smoother HDMI ARC playback.
    • Fixed incorrect playback status and Pre-Gain issues after seeking.
    • Resolved Audible playback issue via Alexa.
  5. Display & UI Updates:
    • New VU Meter designs (requires app v3.1.4).
    • Added remote pairing and Wi-Fi disconnect indicator.
  6. My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4).
  7. Prompt Sound Option: Ability to disable system sounds (requires app v3.1.4).
  8. Wi-Fi Stability: Improved connection reliability, especially for mesh networks.
  9. USB Output Enhancements: Reduced playback stuttering, improved subwoofer sound quality, and added the ability to select either maximum or fixed resolution (requires app version 3.1.4 or later).
Bug Fixes:
  1. LMS Fix: Fixed LMS reconnection issue.
  2. USB Indexing: Resolved USB scanning interruptions for M4A files.
  3. Pop Noise Reduction: Reduced pop noises when switching inputs or adjusting subwoofer settings.
  4. Radio Paradise Fix: Corrected a playback failure issue.
  5. General Fixes: General performance and stability improvements.
Mine updated to this latest version this morning, I then tried the RP beta and went back to the public firmware and it offered me an upgrade (?) to v5.2.705437 which I thought I declined, but it “updated” nonetheless to that older version. I’ll maybe give it a day or so and see if it offers an upgrade back to the latest version, or I’ll drop WiiM a line…
It's now possible to move and rename Preset entries. Funny thing is that all my Presets were renamed automatically with a timestamp appended after the original name, after the update.
hoping that it won't be long before the other Wiims are concerned about them too... """not just the ultra in life"""
an explanation point on the development of each beta project?
